Einleitung
This guide will show you how to remove a key from the keyboard. This is helpful if something gets lodged underneath it or if the key is cracked and you wish to replace it.
Was du brauchst
Slide the plastic opening tool under the key you wish to remove until it is up against the bottom part of the key.
Then, lever the plastic opening tool. It should catch the key.
Finally, keep levering the key until it pops out.
To put the key back in place, simply push down on it until you hear the clips snap into place.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
