Zum Hauptinhalt wechseln
Acer Chromebook CB3-111-C8UB Battery Replacement
Was du brauchst
  1. Acer Chromebook CB3-111-C8UB Battery Replacement, Back Panel Removal: Schritt 1, Bild 1 von 2 Acer Chromebook CB3-111-C8UB Battery Replacement, Back Panel Removal: Schritt 1, Bild 2 von 2
    • Position the laptop upside down with the hinges on the side furthest away from you.
    • Remove the eight 8mm screws with a phillips #1 screwdriver,
    • Remove the four 4.5mm screws with a phillips #1 screwdriver,
  2. Acer Chromebook CB3-111-C8UB Battery Replacement: Schritt 2, Bild 1 von 3 Acer Chromebook CB3-111-C8UB Battery Replacement: Schritt 2, Bild 2 von 3 Acer Chromebook CB3-111-C8UB Battery Replacement: Schritt 2, Bild 3 von 3
    • There is a wire connecting the two pieces of the laptop, from the inside, on the left, be careful not to damage it.
    • Use the plastic opening tool to pry open then remove the plastic base from the rest of the laptop. Start from the right side and work towards the left.
    • Set the plastic base beside the laptop by opening it as if you were opening a book.
  3. Acer Chromebook CB3-111-C8UB Battery Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook CB3-111-C8UB Battery Replacement: Schritt 3, Bild 2 von 2
    • Flip up the small white ZIF connector by using a fingernail or metal spudger.
    • Pull the blue tab to remove the ribbon cable.
    • The ribbon cable is adhered to the plastic so it will take a little bit of force to remove it.
  4. Acer Chromebook CB3-111-C8UB Battery Replacement, Battery: Schritt 4, Bild 1 von 1
    • Locate and remove the two 6mm screws holding the battery in place with a Phillips #1 screwdriver.
  5. Acer Chromebook CB3-111-C8UB Battery Replacement: Schritt 5, Bild 1 von 3 Acer Chromebook CB3-111-C8UB Battery Replacement: Schritt 5, Bild 2 von 3 Acer Chromebook CB3-111-C8UB Battery Replacement: Schritt 5, Bild 3 von 3
    • Pull the battery forward to clear the base from its clips.
    • Lift the battery up so that there is room to grab and unplug the bundled cable connector.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Travis Vo
426 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 22-7, Maness Winter 2017 Mitglied von Cal Poly, Team 22-7, Maness Winter 2017
CPSU-MANESS-W17S22G7
4 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
QUESTION - DO CHROMEBOOKS NEED A BATTERY TO WORK??? My Acer CB3-111-C8UB battery light—which is usually blue because I mostly use it electrically connected—occasionally turns orange, which I suppose means the battery is being recharged. My Windows 10 laptops function fully via their adapter and without any battery. I know, generally tablets have to have a working battery to operate—even via their adapter, but Chromebooks also need a functioning battery to work, even with the charger connected to the electric outlet? Thanks.
J. Laurence - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 1,017
