Einleitung
This guide details the steps to taking off the LCD screen of your Inter-tel IP 8660.
Was du brauchst
Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
8 mm long
11 mm long
While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
Lift up the motherboard out of its housing in the front cover of the phone.
Set the front cover and button pads aside.
Using tweezers, pinch the highlighted connective clips together and depress. Start with the clips in the middle of the motherboard first.
Note: There are four clips, one at each corner of the LCD screen.
Push the black clip holding the ribbon cable out of its casing using the plastic opening tool.
This is done using the spudger to lift one side out of its housing.
Reposition the spudger to the other side of the black clip and push it flush with the other end.
Note: The black clip pushes out of the housing and does not come completely loose.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
