Zum Hauptinhalt wechseln
Inter-tel IP 8660 Motherboard Replacement
Was du brauchst
  1. Inter-tel IP 8660 Motherboard Replacement, Rear Cover: Schritt 1, Bild 1 von 1
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Inter-tel IP 8660 Motherboard Replacement: Schritt 2, Bild 1 von 3 Inter-tel IP 8660 Motherboard Replacement: Schritt 2, Bild 2 von 3 Inter-tel IP 8660 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
  3. Inter-tel IP 8660 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Lift up the back cover and set it aside.
  4. Inter-tel IP 8660 Motherboard Replacement, Internal speaker: Schritt 4, Bild 1 von 1
    • While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
  5. Inter-tel IP 8660 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Lift up the speaker.
  6. Inter-tel IP 8660 Motherboard Replacement, LCD Screen: Schritt 6, Bild 1 von 3 Inter-tel IP 8660 Motherboard Replacement, LCD Screen: Schritt 6, Bild 2 von 3 Inter-tel IP 8660 Motherboard Replacement, LCD Screen: Schritt 6, Bild 3 von 3
    • Lift up the motherboard out of its housing in the front cover of the phone.
    • Set the front cover and button pads aside.
  7. Inter-tel IP 8660 Motherboard Replacement: Schritt 7, Bild 1 von 3 Inter-tel IP 8660 Motherboard Replacement: Schritt 7, Bild 2 von 3 Inter-tel IP 8660 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Using tweezers, pinch the highlighted connective clips together and depress. Start with the clips in the middle of the motherboard first.
    • Note: There are four clips, one at each corner of the LCD screen.
  8. Inter-tel IP 8660 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Flip the motherboard over so that the LCD screen is facing upward.
  9. Inter-tel IP 8660 Motherboard Replacement: Schritt 9, Bild 1 von 2 Inter-tel IP 8660 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Push the black clip holding the ribbon cable out of its casing using the plastic opening tool.
    • This is done using the spudger to lift one side out of its housing.
    • Reposition the spudger to the other side of the black clip and push it flush with the other end.
    • Note: The black clip pushes out of the housing and does not come completely loose.
  10. Inter-tel IP 8660 Motherboard Replacement: Schritt 10, Bild 1 von 3 Inter-tel IP 8660 Motherboard Replacement: Schritt 10, Bild 2 von 3 Inter-tel IP 8660 Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Pull gently on the ribbon cable so that it comes loose from the black clip.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 11-24, Maness Winter 2012 Mitglied von Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 1,101
