Zum Hauptinhalt wechseln
Revlon RVIR1008 Swivel Cord Replacement
Was du brauchst
  1. Revlon RVIR1008 Swivel Cord Replacement, Swivel Cord: Schritt 1, Bild 1 von 1
    • Place curling iron on a flat surface along with the required tools and swivel cord replacement.
    • Curling iron is extremely hot after use. Carefully unplug and let device sit and cool to room temperature before proceeding.
  2. Revlon RVIR1008 Swivel Cord Replacement: Schritt 2, Bild 1 von 1
    • Using both hands, carefully detach both ends of the metal stand from the body by pulling away from the barrel.
  3. Revlon RVIR1008 Swivel Cord Replacement: Schritt 3, Bild 1 von 2 Revlon RVIR1008 Swivel Cord Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Kaufen
    • Unscrew the two 3mm screws from both sides of the barrel clip with a 3.0 flathead screwdriver to remove the clip from the barrel.
    • Set the two screws and barrel clip aside for reassembly at a later point.
    • Clip is prone to pop off from the body due to the weight of the spring. Equally loosen each screw little by little to prevent this.
  4. Revlon RVIR1008 Swivel Cord Replacement: Schritt 4, Bild 1 von 2 Revlon RVIR1008 Swivel Cord Replacement: Schritt 4, Bild 2 von 2
    • Squeeze both sides of the barrel clip spring, and slide the component away from the barrel to remove.
    • Slowly decompress the spring after removal from spring plate to avoid any hazards.
  5. Revlon RVIR1008 Swivel Cord Replacement: Schritt 5, Bild 1 von 2 Revlon RVIR1008 Swivel Cord Replacement: Schritt 5, Bild 2 von 2
    • Remove the 3mm screw holding the metal spring plate in place with the 3.0 flathead screwdriver.
    • Place the screw and spring plate to the side for reassembly at a later time.
    • Removing this screw allows for removal of the barrel from the iron itself. Be sure not to pull on the barrel.
  6. Revlon RVIR1008 Swivel Cord Replacement: Schritt 6, Bild 1 von 3 Revlon RVIR1008 Swivel Cord Replacement: Schritt 6, Bild 2 von 3 Revlon RVIR1008 Swivel Cord Replacement: Schritt 6, Bild 3 von 3
    • Remove the two screws holding the plastic casing together using the 3.0 flathead screwdriver.
    • Remove the front plastic cover from the main body.
    • The plastic cover contains warnings, and is located on the device's handle.
    • Once completed, the inside components will be exposed.
    • Place the two screws and plastic cover to the side for reassembly.
  7. Revlon RVIR1008 Swivel Cord Replacement: Schritt 7, Bild 1 von 1
    • Remove the cylindrical barrel shell by sliding it away from the device's main heating element.
    • Be careful to grip the device firmly and precisely to avoid stripping away the inside components underneath the handle.
  8. Revlon RVIR1008 Swivel Cord Replacement: Schritt 8, Bild 1 von 1
    • Carefully remove the plastic handle casing from the connected inside components, starting from the cylindrical heating element, to the black wire cord.
    • Be mindful to not misplace the On/Off buttons.
  9. Revlon RVIR1008 Swivel Cord Replacement: Schritt 9, Bild 1 von 2 Revlon RVIR1008 Swivel Cord Replacement: Schritt 9, Bild 2 von 2
    • Carefully remove the swivel cord from the female socket.
    • Place the old swivel cord to the side, and insert the new swivel cord into the female socket gently.
    • Touching the internal wiring should be done as minimally as possible in order to avoid any damage to the circuits.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
stuart_le
137 Reputation
1 Anleitung geschrieben
UW Tacoma, Team S3-G2, Liner Spring 2017 Mitglied von UW Tacoma, Team S3-G2, Liner Spring 2017
UWT-LINER-S17S3G2
3 Mitglieder
2 Anleitungen geschrieben
Ein Kommentar
Where can the replacement cord be purchased?
Robert Travis - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 1,539
