Einleitung
Instantly increase the speed of your iMac by upgrading the RAM.
Was du brauchst
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the rear panel slightly near the bottom of the iMac.
Pull the rear panel toward yourself and remove it from the iMac.
Rotate each of the two RAM retaining arms away from the RAM chip.
Pull the RAM chip straight away from its socket.
31 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
como se llama la cajita blanca que esta debajo de las memorias y que funcion tiene?
Easy as pie, instructions were right to the point, thank you.
