Zum Hauptinhalt wechseln
plantronics Voyager pro Battery Replacement
Was du brauchst
Einführungsvideo
  1. plantronics Voyager pro Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • order your battery
  2. plantronics Voyager pro Battery Replacement: Schritt 2, Bild 1 von 1
    • separate rubber case from back of earpiece. you don't need to remove it completely like I did.
  3. plantronics Voyager pro Battery Replacement: Schritt 3, Bild 1 von 1
    • rotate the back away from the case. its basically glued in place with no other fasteners
  4. plantronics Voyager pro Battery Replacement: Schritt 4, Bild 1 von 1
    • you will need to slowly cut through the foam to separate the wires from the battery. then use a soldering iron to desolder the old battery from the board these connections go through the entire board.
  5. plantronics Voyager pro Battery Replacement: Schritt 5, Bild 1 von 1
    • solder the new battery in and test the charging before reassembly.
    • the new battery I ordered was slightly larger but it fit with no problems. I found the wires inside this device to be fairly robust and did not have any issues with wires breaking or dislodging.
    • When I re-assembled I used small amounts of gorilla glue for both the case and the rubber cover. it worked very well and has worked well since. for more details I put together a short video you can check out.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Dan Dunham
3.327 Reputation
29 Anleitungen geschrieben
Ein Kommentar
I accomplished this battery replacement. I was successful. However in my opinion, this device was not meant to have this repair done. It is a “fiddley” affair, but possible. I think it took me two hours, at my leisure. Probably better off replacing the device. Unless…. your just that type who enjoys fiddling around.
Leslie Womelsdorff - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 81
Insgesamt: 4,548
