Einleitung
The lens focusses the light to create an image on the surface of the image sensor. Use this guide to replace the lens.
Was du brauchst
Locate the battery compartment on the back of the camera. It is the panel with the plastic ridges for simple removal.
Slide the battery compartment cover down off of the camera body.
Pry up the battery from the bottom using a finger and remove the batter from the case.
Remove the lanyard by pulling the grey lace through the black string loop.
Pull black string loop through the silver bracket.
Use a plastic opening tool to pry off the ridged back face plate and the black button.
Open the USB cover to expose the small machine screw.
Use the Phillips #00 screwdriver to unscrew the six 0.5cm machine case screws (distributed around the camera body).
Flip open the screen by pulling the loose end of the screen away from the case.
Use tweezers to remove the two outside rubber dots to reveal the two 0.5cm machine screws.
Use the #00 Phillips Screwdriver to remove both screws.
Pull the body apart from the bottom of device just enough to make space to remove the silver plastic strap holder.
Use tweezers to remove the silver plastic strap holder.
Use a plastic opening tool to pry off the lens protector.
Unscrew the two silver 0.5cm machine screws with the #00 Phillips screwdriver.
Lift off the lens protector housing.
Pull apart the two halves of the camera body.
Unscrew both black machine screws holding the lens in place with the #00 Phillips screwdriver.
Carefully remove the compressed springs underneath each of the two screws that were removed in the previous step.
