Zum Hauptinhalt wechseln
Bose Wave Radio AWR1-1W Front Grill Replacement
Was du brauchst
  1. Bose Wave Radio AWR1-1W Front Grill Replacement, Front Grill: Schritt 1, Bild 1 von 3 Bose Wave Radio AWR1-1W Front Grill Replacement, Front Grill: Schritt 1, Bild 2 von 3 Bose Wave Radio AWR1-1W Front Grill Replacement, Front Grill: Schritt 1, Bild 3 von 3
    • Wedge the spudger between the top and front panel on the right side of the device.
    • Push down on the spudger, lifting the front panel away from the top panel until it pops out of the right side.
    • Repeat for the left side of the device.
    • Too much pressure may break the panel, but it should flex slightly before it pops out.
  2. Bose Wave Radio AWR1-1W Front Grill Replacement: Schritt 2, Bild 1 von 3 Bose Wave Radio AWR1-1W Front Grill Replacement: Schritt 2, Bild 2 von 3 Bose Wave Radio AWR1-1W Front Grill Replacement: Schritt 2, Bild 3 von 3
    • Once the panel is released on the left side, wedge the spudger between the top panel and front grill of the device as shown.
    • Apply pressure and move the spudger upward until the front grill pops out.
    • Repeat for the right side of the device.
  3. Bose Wave Radio AWR1-1W Front Grill Replacement: Schritt 3, Bild 1 von 1
    • Lift the front grill away from the device.
Abschluss
To reattach the front panel, press it into the front of the device until it pops back into place.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cassie Harriman
1.033 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S15-G2, Banghart Spring 2017 Mitglied von Cal Poly, Team S15-G2, Banghart Spring 2017
CPSU-BANGHART-S17S15G2
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 15
Insgesamt: 1,753
