Zum Hauptinhalt wechseln
Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement
Was du brauchst
  1. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement, Bottom Panel: Schritt 1, Bild 1 von 1
    • Using a Phillips screwdriver, remove all eleven 7.0 mm screws from the bottom of the Chromebook.
  2. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement: Schritt 2, Bild 1 von 1
    • Find the seam along the edge of the device.
    • Wedge a finger into the groove and separate the panel from the device. If necessary, use a spudger.
    • The panel will still be connected to the device by internal wiring, so pull it off with some caution. It is best to flip the panel to the side once the seam has been broken.
  3. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement, LED Board: Schritt 3, Bild 1 von 2 Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement, LED Board: Schritt 3, Bild 2 von 2
    • Use the flat end of the spudger to lift the retaining flap on the LED board ZIF connector.
    • Pull the ribbon cable from the ZIF connector using tweezers.
  4. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement: Schritt 4, Bild 1 von 1
    • Remove the 4.5 mm Phillips screw.
    • There is a magnet near the LED chip that might attract the screw.
  5. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement: Schritt 5, Bild 1 von 1
    • Use tweezers to remove the LED board.
Abschluss
Alan Shan
382 Reputation
3 Anleitungen geschrieben
Cal Poly, Team S23-G2, Livingston Spring 2017 Mitglied von Cal Poly, Team S23-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G2
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 946
