Einleitung
This guide walks through replacing a faulty battery. It requires removing the keyboard mount. Afterwards, it is relatively simple and requires only a Phillips head screwdriver to finish removal.
Was du brauchst
Flip the laptop upside down so that the lid lies flat on the table.
Remove the nine 6mm Phillips #00 screws that line the border.
Flip the laptop so it is in the upright position.
Open the lid.
Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
Tilt the keyboard mount up.
Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
Gently remove both ribbon cables.
Gently remove the battery’s rainbow-colored bundled cable from the motherboard.
Remove the six 4 mm Phillips #00 screws located along the perimeter of the battery.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Can the HP Chromebook 11 G3 be operated from the power adapter after the battery has been removed?
