Einleitung
This guide walks through replacing a faulty SD card reader module. It requires removing the keyboard mount. Afterwards, it is relatively simple and requires only a Phillips head screwdriver and a spudger to finish removal.
Was du brauchst
Flip the laptop upside down so that the lid lies flat on the table.
Remove the nine 6mm Phillips #00 screws that line the border.
Remove the two rubber feet closest to the hinge using tweezers.
Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
Flip the laptop so it is in the upright position.
Open the lid.
Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
Tilt the keyboard mount up.
Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
Gently remove both ribbon cables.
On the module, use a spudger to lift the small ZIF retaining flap for the ribbon cable connecting the SD card reader to the motherboard.
Gently pull the ribbon cable out of its socket.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
