Zum Hauptinhalt wechseln
Replacing Nikon Coolpix L20 LCD
Was du brauchst
  1. Replacing Nikon Coolpix L20 LCD, LCD: Schritt 1, Bild 1 von 3 Replacing Nikon Coolpix L20 LCD, LCD: Schritt 1, Bild 2 von 3 Replacing Nikon Coolpix L20 LCD, LCD: Schritt 1, Bild 3 von 3
    • Okay, so here is Nikon Coolpix L20 purchased for $8.00. Only issue identified is an obviously cracked LCD screen
  2. Replacing Nikon Coolpix L20 LCD: Schritt 2, Bild 1 von 3 Replacing Nikon Coolpix L20 LCD: Schritt 2, Bild 2 von 3 Replacing Nikon Coolpix L20 LCD: Schritt 2, Bild 3 von 3
    • Open the USB cover
    • Remove the two Phillips screws on this side.
    • Remove the one Phillips screw the left side
    • Remove the three Phillips screws on the bottom
  3. Replacing Nikon Coolpix L20 LCD: Schritt 3, Bild 1 von 3 Replacing Nikon Coolpix L20 LCD: Schritt 3, Bild 2 von 3 Replacing Nikon Coolpix L20 LCD: Schritt 3, Bild 3 von 3
    • Open the battery cover.
    • Separate the rear cover from the front by simply gently pulling the two halves apart. You may have to use your fingernails to separate them. Start at the bottom side, by the AC Power cover. Work your way around the bottom.
    • Once the bottom part of the halves is released, gently pull the back cover in an upward motion. The top is secured by some tabs to the front part.
  4. Replacing Nikon Coolpix L20 LCD: Schritt 4, Bild 1 von 3 Replacing Nikon Coolpix L20 LCD: Schritt 4, Bild 2 von 3 Replacing Nikon Coolpix L20 LCD: Schritt 4, Bild 3 von 3
    • With the halves separated, you are now looking at the LCD in the bracket unit.
    • gently fold the LCD toward the ribbon cable out of the bracket unit. DO NOT try to remove the LCD or to loosen the cable.
    • Remove the four screws from the bracket unit.
  5. Replacing Nikon Coolpix L20 LCD: Schritt 5, Bild 1 von 3 Replacing Nikon Coolpix L20 LCD: Schritt 5, Bild 2 von 3 Replacing Nikon Coolpix L20 LCD: Schritt 5, Bild 3 von 3
    • When you remove this screw, make sure that the shield plate on top of the bracket plate, is just slightly pushed out of the way. This will free the bracket plate.
    • After the removal of the bracket plate, you have access to the connector. Move the white clip gently to the lift (upright) position, to free the cable.
    • The LCD should now easily separate from the logic board.
  6. Replacing Nikon Coolpix L20 LCD: Schritt 6, Bild 1 von 3 Replacing Nikon Coolpix L20 LCD: Schritt 6, Bild 2 von 3 Replacing Nikon Coolpix L20 LCD: Schritt 6, Bild 3 von 3
    • For the reassembly, the trickiest part is to bend the LCD ribbon cable so that it fold under the LCD into the bracket unit.
    • Use caution and patience so as to not cut the cable on the bracket unit.
    • After reassembly, you should hopefully have the same result as I did. Total cost $8.00 for the camera, $15.00 for the LCD and one hour of my time...
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
oldturkey03
782.246 Reputation
119 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
33 Mitglieder
537 Anleitungen geschrieben
3 Kommentare
Very good, I really appreciate it. Thank you.
Linda Musnuff - Antwort
where did you buy the replacement lcd? my l20 broke recently and i’m trying to fix it.
Katherine Lam - Antwort
@katherinelam had to be either ebay or aliexpress. It's been to long ago to remember for sure.
oldturkey03 -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 41
Insgesamt: 7,346
