Einleitung
Remove your rear panel to gain access to your iMac's internals.
Was du brauchst
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the rear panel slightly from the bottom edge of the iMac.
Pull the rear panel toward yourself and remove it from the iMac.
15 weitere Nutzer:innen haben diese Anleitung absolviert.
