Einleitung
This guide will give you step by step instructions on how to replace the Wireless LAN card in your Lenovo Edge 15.
Was du brauchst
With the laptop upside-down, remove all 11 M2 x 6.0mm screws from the cover plate using the Phillips #0 screwdriver.
Gently lift the cover plate off the body of the laptop, ensuring that it does not pull on any components such as the USB ports.
Remove single 3mm screw holding down the end of the card using a Phillips #1 screwdriver.
To reassemble your device, follow these instructions in reverse order. Make sure that connectors are in proper position as shown in step 3.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
