Einleitung
Use this guide to replace your inverter/AirPort cables.
Was du brauchst
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Push the wire clasp away from the AirPort card and toward the display, then rotate up to free it from the RAM shield.
Hold the AirPort card in one hand and use your other hand to remove the antenna cable.
Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
Use a pin (or anything you like) to remove the three rubber feet from the lower case.
Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and away from you until the back tabs pop free.
Remove the small greasy springs with white plastic caps from either side of the battery contacts.
Deroute the cable from around the optical drive, removing tape as necessary, and angle the DC-In board out of its compartment.
Turn over the computer and open it.
Pry up the magnet covering a Phillips screw near the middle of the computer.
Remove the following 7 screws from the edges of the keyboard area.
Three 2 mm Phillips along the right edge.
One 4.5 mm Phillips underneath where the magnet was.
One 6 mm Phillips with a small head in the lower left corner.
Two 6 mm Phillips with large heads, one in the upper left corner and one in the middle
Lift the upper case from the right side and use a spudger or your finger to disconnect the trackpad connector hidden beneath the white plastic tab. Due to model variatons your trackpad connector may be different from the one pictured.
Carefully lift the upper case about half of an inch and move it so that you can access the power and speaker cables.
Lift the upper case enough to disconnect the blue and white power cable from the logic board. Using your fingernails or a dental pick, carefully pry the connector from its socket. Make sure you're pulling only on the connector and not on the socket.
Lift the upper case off completely and disconnect the multicolored speaker cable from the logic board. As before, make sure you're pulling only on the connector and not on the socket.
Remove the following 15 screws:
Fourteen 3 mm Phillips.
One 5.5 mm Phillips in the upper left corner.
Lift the top shield up from the right side, minding the upper left corner, which may catch on the metal framework.
Turn the computer over.
Disconnect the inverter cable from the logic board and deroute it from the metal framework, removing tape as necessary.
Turn the computer back over.
Disconnect the microphone cable at the front of the computer, between the left side of the hard drive and the metal framework, removing tape as necessary.
Use the black plastic handle to disconnect the display data cable from the logic board.
Peel up the yellow tape holding the display data cable to the metal framework and remove the single Phillips screw beneath it.
Support the display with one hand and remove the single Phillips screw on either side of the hinge (two screws total).
When remounting, mind that cables pass under the hinge, not over
Tilt the display back, freeing it from the two metal alignment posts holding the hinges in place, and slide it away from you.
Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
Insert the flat end of a spudger into the gap between the front and rear bezels.
Rotate your spudger until it is parallel to the front face of the display.
Run the spudger around the perimeter of the display to separate the rear bezel from its retaining clips.
Remove the large piece of tape near the lower right corner of the display.
Remove the single screw inserted through the piece of EMI tape near the bottom edge of the display (it's the first of the two clutch cover screws).
Use the tip of a spudger to remove the small washer under the screw you just removed.
Peel the aluminum/EMI tape as one piece off the cast aluminum frame of the clutch hinges.
Remove the pieces of readily removable tape from around the perimeter of the display.
Remove the piece of aluminum tape near the center of the LCD cover.
Peel back the piece of tape securing the display data cable ground loop to the thin steel LCD cover.
Remove the two Phillips screws securing each side of the LCD to the clutch hinge frame (four screws total).
Remove the second of the two Phillips screws securing the clutch cover to the cast aluminum frame of the clutch hinges.
Remove the two pieces of tape over the display data/microphone cables near the lower edge of the display.
Use the tip of a spudger to lift the microphone out of the front bezel.
De-route the microphone cable from around the top and side of the display.
Disconnect the display data cable by pulling its connector away from the socket on the LCD.
Remove the display data cable from the display.
Remove the two pieces of tape covering the inverter/AirPort cables along the lower edge of the display.
Use the flat end of a spudger to push the backlight connector while gently pulling its cables away from the socket on the inverter.
Lift the LCD out of the front bezel and set it aside.
Remove the three Phillips screws securing the reed switch board and the AirPort antenna to the front bezel.
De-route the reed switch/AirPort antenna cables around the side of the display.
Gently peel the inverter cable ground strap off the cast aluminum frame of the clutch hinges.
While pulling the inverter cable away from its socket on the inverter board, use the tip of a spudger to push the connector out of its socket.
Remove the two Phillips screws securing the AirPort antenna to the front bezel.
De-route the AirPort antenna cable along the edge of the display.
If you have a 1.33 GHz 12" G4 iBook, simply remove the Inverter/AirPort cables.
For all other models, use the flat end of a spudger to remove the antenna board from the front bezel.
Remove the inverter/AirPort cables.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
