Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Buffalo Wireless Router zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Buffalo WZR-300HP Wireless Router Teardown, Remove 4 screws: Schritt 1, Bild 1 von 3 Buffalo WZR-300HP Wireless Router Teardown, Remove 4 screws: Schritt 1, Bild 2 von 3 Buffalo WZR-300HP Wireless Router Teardown, Remove 4 screws: Schritt 1, Bild 3 von 3
    • Remove four rubber grommets, They are glued well, so it requires some force.
    • The screw head is non-standard (Torx T9 or T10) with a "security pin".
    • If you lack the Torx bit, you can use a thin flathead screwdriver (appx. 1.5mm) to jam into the slot. :)
    • On my router, I could easily snap off that screw head pin, allowing me to use standard bits.
  2. Buffalo WZR-300HP Wireless Router Teardown, Separate front panel: Schritt 2, Bild 1 von 2 Buffalo WZR-300HP Wireless Router Teardown, Separate front panel: Schritt 2, Bild 2 von 2
    • No need to pry, just pull them apart.
  3. Buffalo WZR-300HP Wireless Router Teardown, Antennas: Schritt 3, Bild 1 von 2 Buffalo WZR-300HP Wireless Router Teardown, Antennas: Schritt 3, Bild 2 von 2
    • There are two fastened antennas
  4. Buffalo WZR-300HP Wireless Router Teardown, Internals top (pt.1): Schritt 4, Bild 1 von 3 Buffalo WZR-300HP Wireless Router Teardown, Internals top (pt.1): Schritt 4, Bild 2 von 3 Buffalo WZR-300HP Wireless Router Teardown, Internals top (pt.1): Schritt 4, Bild 3 von 3
    • Serial interface (4 "pins") are unsoldered, and can be found in the top-right corner of the board (if the Ethernet ports were facing you).
    • A close-up image crop shows the 4 serial through-hole "pins". Pinout:
    • pin1 : VCC +3.3V
    • pin2 : GND
    • pin3 : TX
    • pin4 : RX
    • If you wish to connect using a USB TTL adapter, I suggest soldering female "jumper" wires and routing those outside the case. DO NOT CONNECT TO VCC (do not apply external power!)
    • The serial port is enabled by default, and you can watch Linux boot. If you Google around, you can find how to login to the console (this varies by OS installed on the router).
  5. Buffalo WZR-300HP Wireless Router Teardown, Internals top (pt.2): Schritt 5, Bild 1 von 3 Buffalo WZR-300HP Wireless Router Teardown, Internals top (pt.2): Schritt 5, Bild 2 von 3 Buffalo WZR-300HP Wireless Router Teardown, Internals top (pt.2): Schritt 5, Bild 3 von 3
    • Insert wisdom here.
  6. Buffalo WZR-300HP Wireless Router Teardown, Internals top (pt.3): Schritt 6, Bild 1 von 3 Buffalo WZR-300HP Wireless Router Teardown, Internals top (pt.3): Schritt 6, Bild 2 von 3 Buffalo WZR-300HP Wireless Router Teardown, Internals top (pt.3): Schritt 6, Bild 3 von 3
  7. Buffalo WZR-300HP Wireless Router Teardown, Circuit board bottom (pt.1): Schritt 7, Bild 1 von 3 Buffalo WZR-300HP Wireless Router Teardown, Circuit board bottom (pt.1): Schritt 7, Bild 2 von 3 Buffalo WZR-300HP Wireless Router Teardown, Circuit board bottom (pt.1): Schritt 7, Bild 3 von 3
  8. Buffalo WZR-300HP Wireless Router Teardown, Circuit board bottom (pt.2): Schritt 8, Bild 1 von 3 Buffalo WZR-300HP Wireless Router Teardown, Circuit board bottom (pt.2): Schritt 8, Bild 2 von 3 Buffalo WZR-300HP Wireless Router Teardown, Circuit board bottom (pt.2): Schritt 8, Bild 3 von 3
  9. Buffalo WZR-300HP Wireless Router Teardown, Circuit board bottom (pt.3): Schritt 9, Bild 1 von 3 Buffalo WZR-300HP Wireless Router Teardown, Circuit board bottom (pt.3): Schritt 9, Bild 2 von 3 Buffalo WZR-300HP Wireless Router Teardown, Circuit board bottom (pt.3): Schritt 9, Bild 3 von 3
Alexander Williams
169 Reputation
1 Anleitung geschrieben
Ein Kommentar
Hey man, jst wanna ask can you replace those antennas with hing gin onces?
Tony Gqezengele - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 18
Insgesamt: 1,541
