Einleitung
Use this guide to replace the disk drive in your device.
Was du brauchst
Use a #1 Phillips screwdriver to remove the three screws located in the back of the device.
Pull the top cover off by sliding back from the device once the screws have been taken out.
Lightly lift off the hook on both front rear side and the bottom of the device to remove the front panel
Remove the two screws that attach the disk drive to the frame using a #1 Phillips screwdriver.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
