Einleitung
Is your battery dying often? Does it not hold charge or even not charge at all? Follow this guide to successfully remove and replace the battery from your HP-Omen laptop.
Was du brauchst
The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
The screwdriver should be inserted at the same angle as the screws.
Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
Slide the opening tool along the case perimeter to loosen the bottom case.
Gently pull the bottom case away from the laptop.
Pull the battery cable out from its motherboard socket.
Remove the battery.
Disconnect the power cord from the battery and transfer it to your replacement battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
8 Kommentare
Hello,
I replaced the battery but it is not charging. I know it’s an easy repair, but I checked the pins but not sure where the problem is.
Any ideas?
Thank you
Hi Kiran,
Does the laptop show any indication that it detects the battery?
I’ve replaced the battery with one I bought from here, and I believe it may be faulty? My laptop is not detecting a battery, I opened it back up and followed the guide again to make sure I did everything right, and made sure the battery cord was inserting securely, still nothing.
Hello! Please contact our customer support and we will get the issue resolved!
We took the battery out of your laptop then put it back in because it wouldnt turn on, it turns on now but the left usb ports are not getting powered, is there any way to make sure that they are powered when we get our replacement battery in the laptop?
