Einleitung
Is your screen cracked or smashed? Will it not turn on? Well you are in luck, if you follow our steps on how to disassembly the screen off the HP-Omen computer and reassembly the screen back on. This guides difficulty is moderate and contains 9 total steps that will take you approximately 20-40 minutes to complete it. This guide will also require the pre-requeste of removing the back cover and the battery. You will need only two tools for this repair guide, a Philips #00 screw-driver and a plastic opening tool.
Was du brauchst
The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
The screwdriver should be inserted at the same angle as the screws.
Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
Slide the opening tool along the case perimeter to loosen the bottom case.
Gently pull the bottom case away from the laptop.
Pull the battery cable out from its motherboard socket.
Remove the battery.
Disconnect the power cord from the battery and transfer it to your replacement battery.
Unscrew the six 1.2 mm screws connecting the screen to the body using the #00 Phillips screwdriver head.
Flip the switch up that holds the screen cable in place
Lift up and pull back the cable from the insert
Lift the base of the device up to separate the hinges from the body of the device
Slide the base of the device out from under the hinges
The screen can now be replaced
