Zum Hauptinhalt wechseln
Sony Vaio SVT151A11L Battery Replacement
Was du brauchst
  1. Sony Vaio SVT151A11L Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Sony Vaio SVT151A11L Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the laptop over so that the battery on the underside of the device is revealed.
    • Unscrew the two 11mm slotted silver screws that can be found at the top of the battery.
  2. Sony Vaio SVT151A11L Battery Replacement: Schritt 2, Bild 1 von 3 Sony Vaio SVT151A11L Battery Replacement: Schritt 2, Bild 2 von 3 Sony Vaio SVT151A11L Battery Replacement: Schritt 2, Bild 3 von 3
    • Wedge the plastic opening tool between the back panel and the battery on the top left side of the device.
    • Push down on the plastic opening tool until the battery lifts from the back of the laptop.
    • Grab the battery and remove it from the device.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team S4-G6, Julie Fall 2017 Mitglied von UMass Dartmouth, Team S4-G6, Julie Fall 2017
UMASSD-JULIE-F17S4G6
2 Mitglieder
12 Anleitungen geschrieben
4 Kommentare
Just got the new Sony Vaio SVT151A11L Battery VGP-BPS33 Li-ion, 11.4V, 3760mAh, 43W,Silver , looks in good condition and similar as original. fix it in laptop and works well up to now. one more thing, it costs less than my thought.
julie - Antwort
what size screws and thread type are used for battery mount. i have lost mine
John Sears - Antwort
My computer battery is not contacted what i can do for this problem
Matiullah - Antwort
SVT151A11L
SVT15112CXS
Laptop computer
Battery not connected
What i can do
Matiullah - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 26
Insgesamt: 3,353
