Zum Hauptinhalt wechseln
LG V10 Motherboard Replacement
Was du brauchst
  1. LG V10 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Wedge the flat end of the plastic spudger, or the tip of your finger, in between the back cover and the LG V10’s charging port.
    • If using a spudger, it should not be in the charging port, but between the metal lining of the charging port and the back cover.
    • Carefully lift up on the spudger or with your finger so that the back cover pops up. The rest of the back cover should easily come off by sliding a finger or spudger under the back cover and around the sides.
  2. LG V10 Motherboard Replacement: Schritt 2, Bild 1 von 2 LG V10 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • There’s an impression next to the battery for the user to use their finger to pry the battery out; pry the battery out using your finger or the flat end of the spudger.
  3. LG V10 Motherboard Replacement, Motherboard: Schritt 3, Bild 1 von 3 LG V10 Motherboard Replacement, Motherboard: Schritt 3, Bild 2 von 3 LG V10 Motherboard Replacement, Motherboard: Schritt 3, Bild 3 von 3
    • Using a screwdriver with a J000 Phillips bit, remove the fourteen 3.175 mm screws.
    • Using a plastic opening tool, pry part of the panel up starting from the sides of the battery slot.
    • Use plastic tweezers to release the rest of the panel from plastic bits holding it in place and pry the panel up around the sides surrounding the fingerprint sensor and camera lens; set the back panel off to the side.
  4. LG V10 Motherboard Replacement: Schritt 4, Bild 1 von 2 LG V10 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Carefully disconnect these two connectors by using the flat end of the plastic spudger to wedge the connectors away from the motherboard.
    • Use the plastic tweezers to pry the motherboard out from the plastic bits holding it in place.
Abschluss
After replacing the old motherboard, follow these instructions in reverse order to reassemble the LG V10.
18 weitere Nutzer:innen haben diese Anleitung absolviert.
Joseph
963 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S16-G3, Eyestone Fall 2017 Mitglied von USF Tampa, Team S16-G3, Eyestone Fall 2017
USFT-EYESTONE-F17S16G3
2 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
great guide !
Jordan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 21
Insgesamt: 7,815
