要将新的引线焊接到电路板上,请将一根导线的裸露端放在相应焊盘上的焊珠上。
将烙铁头放在焊锡珠上,直至熔化。
将引线的暴露端滑入焊料中,直到其位于焊料的中心,然后取走烙铁。
以相同的方式继续其他连接,特别注意不要将两个焊盘焊接在一起。
要重新组装您的设备,请按照本指南的相反顺序进行操作。
433 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
36 Kommentare
TIP: Another method which works well for clearing solder from holes (especially on repairs like AC Jacks on laptops) is to use compressed air to clear melted solder from holes. A quick blast with a duster can works well (I have even used a drink straw in a pinch and blown out with a blast of air from mouth). Heat the solder until it liquefies, put the duster straw right above the solder and quickly hit the melted solder with an air blast to instantly clear the hole of solder. This works well on very small holes as melted solder does not always push out cleanly with metal tools. You have to be quick with the air blast because the solder re-hardens rapidly.
just be careful doing this lol, flying molten solder can and will burn you or other components.
Logixal -
Flying solder might also get into places you don't want it. Making shorts and other unwanted connections of which you don't know where they are, so it can give you a very hard time finding them.
This is not IPC standards but for the ghetto approach, it will get the job done. I solder in manufacture settings, run my own shop. This is wrong to a degree but will do. If ifixit would like tips from ILLFIXIT then your more then welcome!
