Einleitung
要更换或取出相机吗?来看看这个吧。
Was du brauchst
排线“3”由FPC型连接器固定。 在取下排线之前,必须先打开这个连接器:用一根塑料棒将白色/黑色塑料片向上翻起来,把剩下的带状电缆固定到位。 塑料片将向上旋转90度,松开排线。
将排线从连接器中取出,然后从iPhone上卸下屏幕。
拆下下面8颗螺丝
主板上的5颗2.3毫米的十字 #00 螺丝
主板上固定相机的2颗2.3毫米的十字 #00 螺丝
1颗在“Do Not Remove”标签下的螺丝
要重新组装您的设备,请按照相反的顺序执行这些指示。
65 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
Ein Kommentar
Thanks for an awesome guide. On mine after getting it reassembled the camera had a green screen. The cable for the camera got slightly disconnected while putting things back together. I'm thinking because the one I got the ribbon was kinda stiff and straight when it had to fold to go back in properly it came slightly unplugged. I just squashed around the camera corner of the case pinching it, of course not to hard, and it came up and works perfectly now. Thanks again, my friend sold me this iphone cheap cause the camera was broke. Thanks to you its good as new.
