Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Using the plastic tabs, lift the hard drive slightly and pull to the left. Remove the rubber mounting brackets from the hard drive. If you are replacing your hard drive with a new one, please note you will need to reuse the rubber mounting brackets in order to secure it in place.
  • Using the plastic tabs, lift the hard drive slightly and pull to the left.
  • Remove the rubber mounting brackets from the hard drive.
  • If you are replacing your hard drive with a new one, please note you will need to reuse the rubber mounting brackets in order to secure it in place.
Hier Übersetzung einfügen
