Englisch
Deutsch
5. Schritt
To disconnect the wide ribbon cable, use your fingers to pull back the black tab until it is loose. Slide out the black plastic tab from beneath the ribbon cable.
  • To disconnect the wide ribbon cable, use your fingers to pull back the black tab until it is loose.
  • Slide out the black plastic tab from beneath the ribbon cable.
  • Once the plastic tab is out, simply pull out the wide ribbon cable.
  • Take care not to flip the tab upside down, as it is not symmetrical. If you are having difficulties fitting it back, it might have flipped at some point.
Hier Übersetzung einfügen
