Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 6 übersetzen
6. Schritt
Remove the five 4mm T4 screws around the battery assembly with a t4 crew driver. Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool. Press the battery from the back  of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
  • Remove the five 4mm T4 screws around the battery assembly with a t4 crew driver.
  • Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
  • Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
  • Do not puncture or bend the battery. Use a small amount of heat to assist in softening the adhesive if necessary.
Hier Übersetzung einfügen
