Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
Remove the hard rubber tab located by the cartridge slot using the plastic opening tool. Be careful not to apply excessive force. Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
  • Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
  • Be careful not to apply excessive force.
  • Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
Hier Übersetzung einfügen
