Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 4 übersetzen
4. Schritt
Using the plastic opening tool, detach the back plate from the front piece. Do not use excessive force. If the back plate does not gently come on double check that all screws were removed.
  • Using the plastic opening tool, detach the back plate from the front piece.
  • Do not use excessive force. If the back plate does not gently come on double check that all screws were removed.
  • Once the back panel is removed, you will be able to see the motherboard and other components within the device.
Hier Übersetzung einfügen
