Englisch
Deutsch
2. Schritt
Remove one screw from the bottom Remove the two screws on the right side. Use a plastic opening tool, or your fingernails, to split the casing apart. Start from the battery compartment and work your way around the case. The case should split easily.
  • Remove one screw from the bottom
  • Remove the two screws on the right side.
  • Use a plastic opening tool, or your fingernails, to split the casing apart. Start from the battery compartment and work your way around the case. The case should split easily.
Hier Übersetzung einfügen
