Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 22
With the crankshaft stopper in place, rotate the engine clockwise until it no longer moves.  The timing bar should slide into place with relative ease.  We are now at TDC If the bar does not slide in easily, check that you are indeed at TDC and not at the top of the compression stroke If you are at TDC, the timing bar may still not quite fit.  As the belt ages it stretches, causing slight variations in the timing.  Using a proper sized open end wrench, you can rotate the cams slightly to get the bar into place
Top Dead Center
  • With the crankshaft stopper in place, rotate the engine clockwise until it no longer moves. The timing bar should slide into place with relative ease. We are now at TDC
  • If the bar does not slide in easily, check that you are indeed at TDC and not at the top of the compression stroke
  • If you are at TDC, the timing bar may still not quite fit. As the belt ages it stretches, causing slight variations in the timing. Using a proper sized open end wrench, you can rotate the cams slightly to get the bar into place
  • The camshafts are keyed to be held with open end wrenches between cylinders #1 and #2
  • The intake camshaft is a 1"
  • The exhaust camshaft is a 1 1/4"
Das Nockenwellenlineal einschieben - sollte leicht gehen.
Wenn nicht, nochmals genau den OT prüfen.
Manchmal passt das Lineal trotzdem nicht, beispielsweise wegen eines verschlissenen Zahnriemens. Dann darf die Nockenwelle ganz leicht gedreht werden.
Es gibt einen Ansatz für einen Maulschlüssel zwischen dem ersten und zweiten Zylinder.
Die Einlassnockenwelle hat einen Ansatz mit SW = 25 mm
Die Auslassnockenwelle hat einen Ansatz mit SW = 32 mm
