Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Use the point of a spudger to pry up and disconnect the battery connector. Bend the battery flex cable slightly so that it will not accidentally touch the motherboard. Bend the battery flex cable slightly so that it will not accidentally touch the motherboard.
  • Use the point of a spudger to pry up and disconnect the battery connector.
  • Bend the battery flex cable slightly so that it will not accidentally touch the motherboard.
Entferne die beiden letzten 3 mm Torx T5 Schrauben, welche die Hauptplatine festhalten.
[* red] Removeblack] Use the two remaining 3mm T5 screws which securepoint of a spudger to pry up and disconnect the motherboard in placebattery connector.
[* black] Bend the battery flex cable slightly so that it will not accidentally touch the motherboard
