Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
Use the point of a spudger to pry up and disconnect the button strip connector. If the button strip's metal clip falls out during the repair, align the clip and push it back into its groove.
  • Use the point of a spudger to pry up and disconnect the button strip connector.
  • If the button strip's metal clip falls out during the repair, align the clip and push it back into its groove.
Hebe die Hauptplatine etwas an, benutze dabei das Plastiköffnungswerkzeug, um an den Stecker zu gelangen, welcher die Hauptplatine darunter anschließt.
Löse den Stecker, indem du ihn von der Hauptplatine wegziehst.
[* black] Slightly liftUse the motherboard using the plastic opening toolpoint of a spudger to accesspry up and disconnect the connector which holdsbutton strip connector.
[* icon_note] If
the motherboard frombutton strip's metal clip falls out during the bottom.
[* red] Disconnect
repair, [https://d3nevzfk7ii3be.cloudfront.net/igi/wYS4OF2xVSYVCTHu|align the connector by pullingclip|new_window=true] and push it away from the boardback into its groove.
[* icon_note] If
[* red] Disconnect
