Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 9
If you successfully removed the entire ambient light sensor, as shown in the first photo, continue to the next step below. If the white diffuser strip detached and remains embedded in the display, as shown in the second photo, you will need to carefully lever it out along the top edge using a thin blade or pry tool. Re-applying heat first may make this task a bit easier. During reassembly, install the diffuser into the display first, making sure it faces the right direction (the front-facing side is shown in the first image, and the rear-facing side is shown in the third).
  • If you successfully removed the entire ambient light sensor, as shown in the first photo, continue to the next step below.
  • If the white diffuser strip detached and remains embedded in the display, as shown in the second photo, you will need to carefully lever it out along the top edge using a thin blade or pry tool. Re-applying heat first may make this task a bit easier.
  • During reassembly, install the diffuser into the display first, making sure it faces the right direction (the front-facing side is shown in the first image, and the rear-facing side is shown in the third).
  • Then, set the ambient light sensor on top of the diffuser. You will need to hold the sensor in position while installing the screws securing the earpiece/sensor assembly. Once the screws are tightened, the sensor will stay in place and work normally.
Wenn du den Umgebungslichtsensor erfolgreich, so wie im ersten Bild gezeigt, entfernst hast, kannst du zum nächsten Schritt übergehen.
Wenn der weiße Lichtzerstreustreifen noch im Display festhängt, so wie im zweiten Bild gezeigt, dann musst du ihn vorsichtig an der Oberkante heraushebeln. Benutze dazu eine dünne Klinge oder Hebelwerkzeug. Wenn du noch einmal Wärme anwendest, geht es etwas leichter.
Setze den Lichtzerstreustreifen beim Zusammenbau zuerst in das Display ein, achte dabei darauf, dass er in die richtige Richtung zeigt. (Die Vorderseite ist im ersten Bild gezeigt, und die Rückseite im dritten).
Setze dann den Umgebungslichtsensor auf den Lichtzerstreustreifen auf. Du musst den Sensor in der richtigen Lage festhalten, während du die Schrauben einsetzst, welche die Ohrhörer-Lautsprecher/Sensoreinheit befestigen. Wenn die Schrauben angezogen sind, wird der Sensor am Platz bleiben und normal arbeiten.
