Englisch
Deutsch
5. Schritt
Use an iOpener to loosen the adhesive beneath the display.  Focus on the top and bottom area of it. After loosening the adhesive in the upper area of your phone, use an iFlex or opening pick and insert it carefully between the mid frame and your display. Do not insert the tool more than approximately 1/16 of an inch on the sides.
  • Use an iOpener to loosen the adhesive beneath the display. Focus on the top and bottom area of it.
  • After loosening the adhesive in the upper area of your phone, use an iFlex or opening pick and insert it carefully between the mid frame and your display.
    • Do not insert the tool more than approximately 1/16 of an inch on the sides.
  • Loosen the adhesive by sliding the along the mid frame.
Verwende einen iOpener, um den Klebstoff unter dem Display zu lösen. Achte dabei insbesondere auf den unteren und oberen Displaybereich.
Verwende, nachdem du den Klebstoff im oberen Bereich des Smartphones gelöst hast, einen iFlex und schiebe ihn vorsichtig zwischen den Mittelrahmen und das Display.
Schiebe den iFlex an keiner der Seiten tiefer als 2mm unter das Display.
Löse den Klebstoff in dem du mit dem iFlex am Mittelrahmen entlang fährst.
[* black] Use an iOpener to loosen the adhesive beneath the display. Focus on the top and bottom area of it.
[* black] After loosening the adhesive in the upper area of your phone, use an iFlex or opening pick and insert it carefully between the mid frame and your display.
[* icon_caution] Do not insert the tool more than approximately 1/16 of an inch on the sidessides.
[* black] Loosen the adhesive by sliding the along the mid frame.
