Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
4. Schritt
Using a T9 Torx screwdriver, remove the two 15mm silver screws that are holding a circuit board/panel to the side of the interior metal casing. Using the same screwdriver, remove the 9mm black screw located farther to the right on the same circuit board/panel. Using the same screwdriver, remove the 9mm black screw located farther to the right on the same circuit board/panel.
  • Using a T9 Torx screwdriver, remove the two 15mm silver screws that are holding a circuit board/panel to the side of the interior metal casing.
  • Using the same screwdriver, remove the 9mm black screw located farther to the right on the same circuit board/panel.
Hier Übersetzung einfügen
