Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
9. Schritt
On the top of the device in the corner directly above the white connector, there is an oval plate held in place by two screws. Remove both of these 7mm screws with a Torx T9 screwdriver. Lift the detached plate off to the side.
  • On the top of the device in the corner directly above the white connector, there is an oval plate held in place by two screws.
  • Remove both of these 7mm screws with a Torx T9 screwdriver.
  • Lift the detached plate off to the side.
  • The plate is still connected to the device.
Hier Übersetzung einfügen
