Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
2. Schritt
Flip over the device again, so that the bottom is facing upwards. Using a Torx T9 screwdriver, remove the two screws located on opposite sides of the metal casing. One is near the fan vent, and the other is near the power supply vent.
  • Flip over the device again, so that the bottom is facing upwards.
  • Using a Torx T9 screwdriver, remove the two screws located on opposite sides of the metal casing. One is near the fan vent, and the other is near the power supply vent.
  • The left screw is 11mm and the right screw is 7.5 mm.
Drehe das Gehäuse wieder um, so dass die Unterseite oben liegt.
Entferne die beiden Torx T9 Schrauben an den gegenüberliegenden Seiten des Metallgehäuses.
Die linke Schraube ist 11 mm lang, die rechte 7,5 mm.
