Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2
Flip over the device again, so that the bottom is facing upwards. Using a Torx T10 screwdriver, remove the two screws located on opposite sides of the metal casing. One is near the fan vent, and the other is near the power supply vent.
  • Flip over the device again, so that the bottom is facing upwards.
  • Using a Torx T10 screwdriver, remove the two screws located on opposite sides of the metal casing. One is near the fan vent, and the other is near the power supply vent.
  • The left screw is 11mm and the right screw is 7.5 mm.
Drehe das Gehäuse wieder um, so dass die Unterseite oben liegt.
Entferne die beiden Torx T9 Schrauben an den gegenüberliegenden Seiten des Metallgehäuses.
Die linke Schraube ist 11 mm lang, die rechte 7,5 mm.
[* black] Flip over the device again, so that the bottom is facing upwards.
[* red] Using a Torx T9T10 screwdriver, remove the two screws located on opposite sides of the metal casing. One is near the fan vent, and the other is near the power supply vent.
[* icon_note] The left screw is 11mm and the right screw is 7.5 mm.
