Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
Schritt 7 übersetzen
7. Schritt
Locate the two connectors directly above the battery on the left side of the device. Remove the battery connector cable located to the right of the charging port connector cable using a nylon spudger by prying underneath it and popping it up. Remove the charging port connector cable to the left of the battery cable using a nylon spudger by prying underneath it and popping it up.
  • Locate the two connectors directly above the battery on the left side of the device.
  • Remove the battery connector cable located to the right of the charging port connector cable using a nylon spudger by prying underneath it and popping it up.
  • Remove the charging port connector cable to the left of the battery cable using a nylon spudger by prying underneath it and popping it up.
Hier Übersetzung einfügen
