Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
Wedge the plastic opening tool between the gap created by separating the screen and body of the phone in the right hand corner to hold it open. Insert the nylon spudger into the lower left corner of the screen and pry the screen toward you. Continue to insert the plastic opening and spudger tools around the phone, and pry open the screen until it is fully separated from the device.
  • Wedge the plastic opening tool between the gap created by separating the screen and body of the phone in the right hand corner to hold it open.
  • Insert the nylon spudger into the lower left corner of the screen and pry the screen toward you.
  • Continue to insert the plastic opening and spudger tools around the phone, and pry open the screen until it is fully separated from the device.
  • Remove the screen gently and slowly as the screen may crack otherwise.
Hier Übersetzung einfügen
