Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Wedge the plastic opening tool underneath the motherboard near the battery and use the flat end of the spudger to create a gap. Gradually make this gap bigger so that  the area is still loose when you remove the spudger. You may want to use a thinner prying tool instead of the plastic opening tool  to make this step easier.
  • Wedge the plastic opening tool underneath the motherboard near the battery and use the flat end of the spudger to create a gap.
  • Gradually make this gap bigger so that the area is still loose when you remove the spudger.
  • You may want to use a thinner prying tool instead of the plastic opening tool to make this step easier.
Hier Übersetzung einfügen
