Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 8 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
If your replacement display did not come with pre-installed speaker grilles or a front-facing camera bracket, carefully remove these parts from your old display. Follow the rest of the guide to install them on a new display. To remove the camera bracket, apply heat, then use a thin metal blade to pry the bracket away from the old screen.
  • If your replacement display did not come with pre-installed speaker grilles or a front-facing camera bracket, carefully remove these parts from your old display. Follow the rest of the guide to install them on a new display.
  • To remove the camera bracket, apply heat, then use a thin metal blade to pry the bracket away from the old screen.
  • There are two layers that make up the speaker grille—the metal mesh grille, and a layer of thin fabric mesh behind it. Use tweezers to peel both layers off of the old screen together. Do your best to not separate those layers at all.
  • Make sure to install the grilles and gasket before applying display adhesive.
  • Cut two corners of a pre-cut adhesive card so that each side is no more than 12 mm (0.5 inches) long, or cut four 12 mm (0.5 inches) strips of double-sided adhesive.
  • The adhesive strips should be no wider than 1 mm.
  • Apply the adhesive strips to the edges of the flat side of the front-facing camera bracket. When you're done, there should be adhesive on all four edges of the camera bracket.
  • Gently press the adhesive into place using your finger or a spudger.
Möglicherweise wurde dein Ersatzdisplay nicht mit vorinstalliertem Lautsprechergittern oder der Frontkameradichtung ausgeliefert. In diesem Fall musst du diese Teile sorgfältig vom alten Display ablösen und mit Hilfe der nachfolgenden Anleitung auf das neue Display übertragen.
Zum Entfernen der Kamerahalterung musst du sie erst erwärmen und dann mit einer dünnen Metallklinge vom alten Display abhebeln.
Das Lautsprechergitter besteht aus zwei Schichten — ein Gitter aus Metallgewebe und dahinter eine dünne Lage aus Stoffgewebe. Ziehe mit einer Pinzette beide Schichten gemeinsam vom alten Display ab. Trenne sie dabei auf keinen Fall voneinander.
Achte darauf, dass du die Gewebe und die Dichtung vor dem Anbringen des Klebers befestigst.
Schneide zwei Ecken eines vorgestanzten Klebebogens so ab, dass keine Seite länger als 12 mm ist, oder schneide vier 12 mm lange Stücke von doppelseitigem Klebeband ab.
Die Klebestreifen dürfen nicht breiter als 1 mm sein.
Bringe die Klebestreifen an Kanten der flachen Seite der Frontkamerahalterung an. Wenn du fertig bist, sollten an allen vier Kanten der Kameraöffnung Klebestreifen sein.
Drücke den Kleber vorsichtig mit einem Finger oder einem Spudger fest.
