Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3 übersetzen
3. Schritt
Use a nylon spudger to carefully pry the top back panel off. While removing the top back panel, be careful not to break the four pin connector located underneath. Disconnect the four-pin connector and remove the top back panel from the computer.
  • Use a nylon spudger to carefully pry the top back panel off.
  • While removing the top back panel, be careful not to break the four pin connector located underneath.
  • Disconnect the four-pin connector and remove the top back panel from the computer.
Hier Übersetzung einfügen
