Englisch
Deutsch
2. Schritt
Locate the control arm on the underside of the display. You will need to detach this to access the screws. Place a finger behind the control arm. Separate the display unit from the control arm by pulling down with your finger and using your other hand to push the display unit up.
  • Locate the control arm on the underside of the display. You will need to detach this to access the screws.
  • Place a finger behind the control arm.
  • Separate the display unit from the control arm by pulling down with your finger and using your other hand to push the display unit up.
  • Removing the control arm takes a moderate amount of force.
Hier Übersetzung einfügen
