Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
9. Schritt
Slide the spudger along the side of the phone until you get to the clip securing the display to the rear case. With the spudger right next to the clip, carefully twist the spudger to pry the display away from the rear case and release the clip. With the spudger right next to the clip, carefully twist the spudger to pry the display away from the rear case and release the clip.
  • Slide the spudger along the side of the phone until you get to the clip securing the display to the rear case.
  • With the spudger right next to the clip, carefully twist the spudger to pry the display away from the rear case and release the clip.
Schiebe den Spudger an der Seite des Smartphones entlang, bis du zu der Raste kommst, mit der das Display am Rückgehäuse befestigt ist.
Verdrehe den Spudger, um das Display vom Rückgehäuse wegzuhebeln und die Raste zu lösen.
[* black] Slide the spudger along the side of the phone until you get to the [https://d3nevzfk7ii3be.cloudfront.net/igi/ipIFdK2Ydfo1dXRR|clip securing the display to the rear case|new_window=true].
[* black] TwistWith the spudger right next to the clip, carefully twist the spudger to pry the display away from the rear case and release the clip.
