Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 24 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Step 5
Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
  • Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
  • When replacing these screws, you must reinstall each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
  • During reassembly, make sure to reinstall the two screws on the right into their appropriate locations, and not the DVI port anchor holes.
Hier Übersetzung einfügen
