Zum Hauptinhalt wechseln
Englisch
Deutsch
4. Schritt
Peel off the rubber insert in the inner arm rest. The insert should be glued down if this is the first time you are disassembling the door.
  • Peel off the rubber insert in the inner arm rest.
  • The insert should be glued down if this is the first time you are disassembling the door.
  • Unscrew the inner arm rest panel with the phillips screwdriver. This screw is holding the arm rest panel together.
  • On the passenger side the screw will be inside the upright handle. Pry off the handle cover and unscrew the screw hidden inside.
Hier Übersetzung einfügen
