Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
follow steps to remove bottom case if needed. how to remove bottom case. with bottom case removed, begin with disconnecting the battery. this is done by fist moving the ribbon cable out of the way of the screw that secures the battery contact. Once unscrewed, lift flap to interrupt contact to battery. with bottom case removed, begin with disconnecting the battery. this is done by fist moving the ribbon cable out of the way of the screw that secures the battery contact. Once unscrewed, lift flap to interrupt contact to battery.
  • follow steps to remove bottom case if needed. how to remove bottom case.
  • with bottom case removed, begin with disconnecting the battery. this is done by fist moving the ribbon cable out of the way of the screw that secures the battery contact. Once unscrewed, lift flap to interrupt contact to battery.
Entferne das Unterteil mit Hilfe dieses Teardowns.
Wenn das Unterteil entfernt ist, kannst du den Akku abtrennen. Zuerst musst du das Flachbandkabel aus dem Weg schieben, um an die Schraube zu gelangen, welche den Akkuanschluss befestigt. Wenn sie entfernt ist, kannst du die Klappe hochheben, um den Akkuanschluss zu trennen.
