Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 5 übersetzen
5. Schritt
with the antenna bar removed, it is now time to remove display assembly. it is recommended to have the display at 90degree angle for removal. remove the screws indicated by the red circles. (*there will be a plastic black covering over the display hinges. it will need to be removed first to expose the hinges.) with the antenna bar removed, it is now time to remove display assembly. it is recommended to have the display at 90degree angle for removal. remove the screws indicated by the red circles. (*there will be a plastic black covering over the display hinges. it will need to be removed first to expose the hinges.)
  • with the antenna bar removed, it is now time to remove display assembly. it is recommended to have the display at 90degree angle for removal. remove the screws indicated by the red circles. (*there will be a plastic black covering over the display hinges. it will need to be removed first to expose the hinges.)
Jetzt kann auch die Displayeinheit herausgenommen werden. Zum Ausbau ist es gut, wenn sie im 90° Winkel steht. Drehe die rot markierten Schrauben heraus. (Über den Scharnieren des Displays befinden sich schwarze Kunststoffabdeckungen. Um an die Scharniere zu gelangen, müssen diese zuerst entfernt werden).
